Super Jet Mild Pistons scoring and seize HELP
Hej Flash-FX. Removed the flywheel cover and it smelled strongly of gas in there. See images is that excessive gunk? Havent pressure tested yet.
Is this gunk normal? Smelled crazy like gas when i popped the cover?
schicks
Karma Enforcer
West Michigan
not normal. Must do a leak down test to determine where the leak is coming from, could be crank seals, could be case mating surface. Air leaks cause the motor to run lean and blow up, so yes, that would cause piston scoring.
Weird. Performed the leak down test and it held 10psi for 10 minutes without dropping. Carbs didnt lose pressure either. Hmmm.
Tyler Zane
Open Your Eyes
Personally if I where going this far I would do crank seals also. Your half way there, new crank seals, gaskets and a crank inspection will ensure you have a good bottom end to last a long time.
Stockton
You might adjust your riding style and only pin the throttle wide open for 3 to 5 seconds max. Wide open for 45 seconds is along time
Ok, so here is the next piece in the puzzle: check pic of the head. I dont know what to make of this. Both domes look like this.
Sent from my iPad using Tapatalk
