It's squish, not squash. :biggthumpup:
You will not decrease squish by cutting the dome. If anything, you'd increase it.
Generally, you measure squish and compression.
Then, run the numbers and mill the head to obtain desired compression while keeping squish reasonable.
After that, squish is checked again. If it's out of desired spec, it can be cut a bit larger without having a large effect on cranking compression.
