- Sydney
to the untrained eye, you can barely tell a 00 cyl from a 12/12, but even a slight difference equates a noticeable power difference. and when you put a motor on the degree wheel to measure port timing, you read it at the sleeve port opening, not the aluminum casting inside the port window. when porting transfers, you direct the charge up and to the back of the cyl.View attachment 267456 View attachment 267456 View attachment 267457 View attachment 267458 Not a close a match as I thought
