- Idaho
From the FFP limited instructions
Some engines may react differently from the above. For example, while testing the 650 Super Jet we found that we gained top end performance by running the top screw open and the others closed. You may use any combination of the three screws to achieve the desired performance. However, AT LEAST ONE SCREW MUST REMAIN OPEN AT ALL TIMES TO PREVENT DAMAGE TO THE PIPE.
