Most shocking
Tuscaloosa, AL
I have broken poles, unless you rip the outer sleeve, your not gonna pull the cable. Only way is the flopping pole to hit so that the throttle gets wedged open.
When the cable gets pulled too tight, it can pull the throttle plates open.
I have had this happen when using a cable that was too short.
Turning right would pull the cable tight and pull the plates open.
yamanube
This Is The Way
Staff member
Mandalor
Same here, somehow my throttle cable got stuck under my gas tank.
Tuscaloosa, AL
But, that is because of an improper cable.
Wait, thinking about the mechanics of it, as the sleeve bends, it technically could stretch the cable some. hmmmmmmmmmmmmmmm
Think about it. Both ends of the cable are attached, one to the pole, one to the throttle wheel.
If you break the pole and pull the broken piece away from the ski, it will pull open the throttle plates.
Tuscaloosa, AL
But, if the end of the cable is still in the cable mount where it exits the pole, this would not be possible. Also the cable would still be mounted at the carb plate mounts. you are not changing the distance. Also, techically your steering plate would have to shear from its mounts (bearing) to put any influence on the throttle cable itself. In other words, if the sleeve is 10', the amount of cable inside the sleeve is still 10'. If the pole breaks, the sleeve is still 10'. (all of this is based on both ends of the cable still being in their mounts.)
yamanube
This Is The Way
Staff member
Mandalor
Im not sure how it works and dont want to use my brain right now but when my cable was pulled to tight due to improper routing it would go WFO when the steering when to full lock right.
Tuscaloosa, AL
you do get some cable stretch if your cable tension is set too tight which will open the throttle a bit. Most likely it was not opening the plates all the way, but when the ski is out of the water and you do this, it only takes a small amount of open throttle to get WOT RPM's. (No Load on the motor)
Me and Matt are just sparring with each other, it is an interesting theory.
What cable mount where it exits the pole? :confused:
It's a bit abstract trying to explain it. I know from first hand experience that it does happen.
That's been my experience as well.
same here...
I am just wondering once the ski breaks loose like that and you would get a hold of it on the water how would you go about stiopping it ?
I am trying to see myself riding on the ski with a stuck full open throttle and trying to remove the hood at the same time to pull the plugs..??? :bananajump::bananajump:
tightithrash
Zack Bright. I Thrash.
Oceanside, CA
ah i see...............well..............ride around like a bat outa' hell until you run out of gas..... keep doing super deep subs until you choke the motor from less air, not water.........toss your hood and cover the carb.............toss your hood in the surf, pull the gas cap and stomp perfect flips and rolls until all your gas fall out..........ummmmm yep.
Tuscaloosa, AL
Oh crap. I have been sick as hell with the sinus crap, bad bronchial coughing spasms. What was I thinking.... Steering cable!!!!!!!!!!!! sorry about that, I must be really delerious.
