Super Jet Motor accelerating out of water help
ATB
RICKTER XFS 1100CC
granada spain
hello.
a month ago, if I accelerate the engine out of water in my engine 760cc bike it gives me the maximum speed and I can not stop it.
I have to plug the air inlet or remove the gasoline.
my engine has installed a total loss, if it helps you.
not that it can be.
a greeting and thanks
SXIPro
JM781 Big Bore
air leak could be a lot of places. crank seals, at any number of gaskets, primer, etc etc. You need to do a leak down test to find the exact location of the leak and fix it.
Big Kahuna
Administrator
Tuscaloosa, AL
I would check to see if your butterflies on your carbs are set the same. If one is open more than the other then it can cause your ski to free-rev.
