61x is a great package and you will be very happy with it.
http://www.x-h2o.com/index.php?threads/pros-cons-701-61x-vs-701-62t-vs-760-64u.62130/
Good to know ill see if i can pick up a 61x then, thanks for the link and all your guys input.
Had a 650sx. Put a small pin 750 bored 1.5mm, 175psi head, dual 40mm SXR carbs, 650 stator and flywheel. Ran both PJS and fully modded and port matched oem exhaust. 9/17 skat prop. It was good, for a kawi motor. It was not good compared to a Yami 701 based motor. I sold it and have been super happy ever since.
Ill have to order one of these up once i secure an engine
I have run several Yamaha swaps in x2s and Kawasaki engines as well.
By far and away my favorite was a Yamaha 760 bored 2mm over (I think) with high comp head,, lightened stock 61x flywheel and 61x electronics, freestyle porting and a TNt copy c4 chamber.
That ski was a 100% absolute monster. Power for days. Great top end, outrageous bottom end.
It died in the garage... had a pin hole wire in the start stop harness I didnt know about. Rinsed the ski after riding, went to dinner. Came home to a house full of 2 stroke smoke and a x2 that ran until it had seized.... RIP my friend.
All depends on your fab ability and how much you want to spend.
There use to be a guy in Lousianna that had several of the PJS Supercylinder motors, these were 800cc motors. if you could find something like that. HPT had a stock of Kawi Aftermarket Cylinders, Think they were Able Cylinders. May want to check with him. May be a decent option or a DASA Kawi based setup..........
How do I get ahold of hpt I got all the able heads for those cylindersThere use to be a guy in Lousianna that had several of the PJS Supercylinder motors, these were 800cc motors. if you could find something like that. HPT had a stock of Kawi Aftermarket Cylinders, Think they were Able Cylinders. May want to check with him. May be a decent option or a DASA Kawi based setup..........
He is on here also...............HPE Matt hole shot Hobson on Facebook ??
