Also check to make sure your carbs are both opening up if you are running duals. I have had my carb linkage come loose and keep one carb butterfly closed while the other one opens fine. Feels like you have dropped a cylinder when it happens. Might want to sheck your reeds too. Make sure the reed block hasn't come loose from the manifold.
JAM
JAM
