MSD ignition enhancer wiring advice needed.
Hey guys , wiring up an msd ignition , and not 100% sure about a couple of connections... 1. does the brown wire on msd connect to the brown/white striped old wire and 2. does the white wire on msd connect to the white/red striped old wire... ? Also would there be any need to smear on some petroleum jelly (or some other gel) to help seal up the old electric box when finished... ? Thanks
usa
brown/white stator wire to brown on msd
connect white from start/stop to white on msd first
then connect white/red to msd white on 61x stators
jumper white wire that is female/female connector, on white/red from stator is used on late models with 62t stators then to msd white
usa
stock msd setting is about 8000 rpm
i set them closer to 9000 rpm
turn screw to the right to max out then back 1/8 turn
then lock jam nut down lightly
  • Like
Reactions: mk1
