You want some feedback on Wax's CDI?
Ok, they are are nice little CDI. Fully laptop programmable right down to 50rpm increments, which allows very precise curve structure. You get the choice of 2 curves and you can control water injection.
I'm not sure of max advance, but I know it's right up there. Most people won't use any more than 40 deg anyway.
I've used the Wax CDI for some time, and found it to be the easiest starting CDI....comprable to the stock one.
It also comes pre-programmed, but the difference is that you can actually speak to Jared and have him help you work out your OWN curve, based on your setup. He's an actual person too, so if you ever have any trouble, you can just ring him direct and he'll help you out.
On a side note, the Vilder comes pre-programmed too.
