GIL
Power In The Hands Of Few
- Cullman AL
Why the F did I go sooo freegin long w/o T/L??? It took me about an hour to install and setup and is freegin awesome!!!
How long can you run two bilge pumps on a TL setup?
Good news, Gildo, WalMart has a badass marine charger for like 70 bux.
You sure it only took you an Hr to install?:bsflag: Who helped you do it
So we gonna see some pics of the "roll" now:Banane35:
It came to me already wired up and air gap set and timing set for a mtr identical to mine. All I had to do was install the box where original box went, install plate in timing cover and flywheel and hookup battery cable, starter cable, and mount my on/off switch.
Hey Gil, you really should check the air gap yourself.
There is no "identical" motor with identical air gap.
