- Ocala florida
Superjet 701 dry pipe type 4 water injection im getting red light at startup but no green light with throttle rev looked for some info on settings but no real help anyone have any info that will help
Ok ill check in the amThose LED's burn out.. I'd disconnect the sprayer hose and see if it's injecting and when it's injecting..
Im not sure how to set the controls ither im a newbiOk ill check in the am
You could put a test light on the wires coming to the soliniod and test the control signal from the msd switch.. My soliniod was bad to, it fell apart after awhile lol..
I used continues injection and adjusted with a jet on mine when thought my msd was bad. So you got other options if needed..
U meanYou could put a test light on the wires coming to the soliniod and test the control signal from the msd switch.. My soliniod was bad to, it fell apart after awhile lol..
Did u just run a cooling line to the injection needle. So it sprayed all the time? Doesnt rhat take away alot from mid to top?You could put a test light on the wires coming to the soliniod and test the control signal from the msd switch.. My soliniod was bad to, it fell apart after awhile lol..
