I have an MSD enhanser on my SJ but mine only sparks when i let go of the start switch. it ran perfect until i filled up the engine bay with salt water up to the carbs
-I have pulled the boots back, stripped some rubber to get fresh wires and cut them then re attached them but still the the same thing: only sparks when i let go of the start button
-I also unhooked the black and white connector to the start stop switch and still the same thing happens: only sparks when i let go of the start button
-I tried switching the br8es plugs from my working 800 sxr into the superjet but it does the same thing.
- I opened the ebox and there were only a couple of drops of water in it.
- I have used my fluke multimeter and put the continuity tester on and put one lead onto the negative battery terminal and then one lead onto my engine block and it reads continuity. i also put the ohm setting on and its jumps from 100 somthing to OL
@Harbor since mine used to run good with the MSD as is... why would my correcly wired MSD enhanser cause it to spark when releasing the start button?
Good question.... You might pull the stator cover and look and see if it's filled with salt water
