- Norwich, Uk
Hi i brought a second hand ignition for my blaster 1. i swapped the wires over and im 80% sure iv done it correctly.
Pink to pink, white to white, white male connector to white with red stripe, brown to brown with white stripe, orange to orange, black to black,
iv split the red wire on the blaster next to where the fuse goes and put the red wire from the msd with both male and female connectors in to connect it back up if that makes sense? Theres 2 places where this could go i think. Dont know if it would make a difference?
And iv put the earth where the other earths go.
When i try and start it it fires and back fires but doesnt run.
Have i done anything wrong or is it just a faulty ignition? I brought it from someone who said its not been tested and gave me no gaurantees it would work i just thought it would.
Also i havent played around with the adjusting screw on top. Dont know if that will make any difference?
