DAG
- Charlotte, NC
By chance are you running the shifty mod?
I meant that question to be for the original poster or are you also having the same issue Corey? I've seen the shift mod intermittently latch closed which simulates holding down the Start button and makes you think the noid is the problem as the symptoms are the same, release of amperage to the start circuit. You can unhook the purple wire and ground it and it will kill a stuck shifty. Maybe something to investigate
Sure, SeaDoo Solenoid Relay Kit 295500900. The kit come with the GM style waterproof connector that plugs into the solenoid.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/311801735229
If it is the shifty mod that is stuck when you put a new relay in should it have the same symptoms of trying to start on its own or would it act normal for a bit and happen again? I am ordering an extra relay and wondering about another shifty module too for an extra
I run it externally
Yep
This is accurate, @justjoe sent me this picture the other day.
Replaced mine, hopefully it never sticks again.
Had the same thing happen to a brand new MSD relay. What a POS, chinese crap.
Shifty module: 2 relays. One relay powers on the brain when lanyard is in, the other relay cuts power when stop button is hit.
