Setup my RRP water box with some Hydroturf so it doesn't rub out and vibrate
All new oem motor mounts. Freeride innovations engine keepers. All clean oem hardware out of donor sitdowns.The motor is aligned and installed. Polished up the head shell quick.
Setup my electrical box above my battery. Im using OCD battery cables and I have to order a new set. It will clean up a bit when I make shorter cables. I used the foothold washers so it's flush to mount it. I'm using and e box shell out of a sitdown which had threads tapped in the rear.
Drilling some pissers in the side.
Ready to fire up!!
