You made the same mistake I made..... Bit off more than you can chew, and now you don't get to ride this summer. Haha!
Looks good!
That is my worry lol. This weekend I will be putting in a good 16-20hrs on the ski so hopefully I can make a good dent. Here's my goal this weekend:
- finish prepping engine bay
- finish cabosil on rocker sides and fill bond lines.
- lay down 2-3 layers of biax on the rocker inside
- layer of biax on outside of rocker
- sand down and finish rough shaping the rocker and nose
- shape and set up about 4 layers of biax for the pole forward mount and glass the top deck to the bottom at the rocker
- lower and move gunwales forward (decided against widening the tray out to the bond rails)
- maybe get a couple layers of glass laid in the angled shorten at the rear of the hull.
- and if everything goes phenomenally (which is unlikely lol) make some foam shapes to get the rails widened
