oxnard111
Creative RE Purchasing
- so Cali, Ventura/Oxnard area
the waterbox will work fine,the long hose will work but it will be a pita to on get the first time.
the mid shaft is the same but the bearing carrier is different.
the steering cable is slightly different but if you have a round pole then youve already dealt with that
ride plate will work fine too
only 90-93 were differnent
90-93 = small diameter bearing housing.
94+ = large bearing housing
Shaft lengths are the same any year.
