- Bay Area, CA
Shot the first coat of Rust-Oleum topside primer... Kinda annoyed I had the whole ski blocked to 320 grit and this stuff calls for 80grit sanding as prep, had to rough up the whole hull lol looks like it covers pretty well, I will sand 320 between coats and hopefully all the 80grit scratches are filled after the second coat...
What is the preferred orientation for painting? I have an engine hoist so I could stand it up....I'm kinda screwed because the top half becomes the bottom half at the rocker so If i spray bottom and top separately I'll have to blend the nose well and carefully cut/buff the wet edge.
I got lucky spraying in the open because it's normally pretty windy here, and primer is pretty forgiving (especially knowing I'm going to block it between coats) but I don't think I'll have as much success shooting a gloss topcoat outside so I might have to carefully take the ski to work and use the spray booth there. Then I'm at the mercy of the production schedule and waiting for it to be available. My goal is to have the ski ready by July, so it just might just get a full backyard jobby...
