Nice mod @speedysprocket
Do you think the Thrust trim ring serves a similar function as the flow guard you made?
Anything is possible, just depends how much work and time you want to invest. The stock ring with the rubber may be the most efficient design. I haven't had one to play with though.Wonder if you could cut and heli-arc the actuating arm on one of the Yamaha oem trim rings with the rubber side flaps to work with the XMetal bracket/cable location? That could be another long term "fix".
Do you mean the blue coupler over the trim ring being the guard?@NVJAY775 was a big difference after adding the guard?
