- Jersey Shore
Here is the build I just completed the night before Wavedaze. It was a basic build for my 7 and 9 year old, to rip this summer.
The ski, both top and bottom deck, are yet another great product by TigerCraft. The bottom is a lightweight Kawasaki SXR hull and the top, Tony calls a Speedster. We were given a bare top and bottom and away we went!
The motor is a new bone stock (minus filters and exhaust) 750, that we took from a 1995 zxi showroom leftover, that never saw water! It was setback to get the weight a little further back. The internal fill 5gal tank and foam is from a 750sx.
The ebox started out as a rear solenoid/coil housing from a Seadoo. It now contains all the electrics, including the switch & power for the bilge.
Handle pole, steering system, chin pad and pole bracket is from Aura Alloys. Aurabillet@gmail.com
Pump is standard 140mm with R&D afterburner and SXR prop. An extended composite ride plate an R&D grate, finish off the hull.
Special thanks to;
Tony of TigerCraft, for giving us the hull and allowing me to build it a little outside-the-box. Tigercraftusa@gmail.com
Mark of RadDudes for all the support.
Robin of Rhaas Products
Wayne of WetWerks
Chris Rauen for the artwork
Kelly at Jettrim for the new stichin'
Tim at ZForce Racing
Zimmy for the American/S.African pole pad
And everyone that's just been awesome to my boys at all these events an races.
Thank you!
My 7yr olds first ever time riding a ski
Test ride first run.
Special thanks to;
Wayne of WetWerks
Thank you!
