Surfriding My new mods
Hab
Dubai
These are the mods im looking to install, want some feedback before the purchase on some certain things like for example:
The D cut ride plate i chose will it be good for the surf , i heard from many that the nozzle will keep breaking off but im not sure
also the solas pump with a stock engine will be any use or will it be a waste
and any other feedbacks from your side also would be great
Factory Pipe - Yamaha B-Pipe Exhaust Kit
Select
Limited
Blowsion Girdled Head Kit
Color
Red
Primer Kit - Mikuni Dual
Flow Control Valve - Pro Series
Color
Red
Blowsion Steering System without Turnplate
Blowsion Shortened Turnplate
Blowsion Handlebars - Blaster & Sport Class
Handle Pole Spring - Yamaha Superjet 1996+
Blowsion Carbon Ride Plate D-CUT - 2008+ Superjet
Solas Yamaha Magnum Pump 144mm
ODI Xtreme Grips Black (130mm)
ODI Aluminum Lock Ring Set
Color
Red
Blowsion Billet Throttle Lever
Color
Red
Hood Strap Kit
Handle Pole Limiting Rope
964Chris
FREEdumb obtained
TEXAS
Looks like a good choice of mods. The pipe with flow control valve and the higher compression head will give you a good bump in power/snap for the surf. Solas pump will give you more hook up in the white wash.....great for the surf. Make sure you prop appropriately. Only issues with breaking nozzles is if you're landing tail first in shallow water.
Hab
Dubai
Good to know, thanks!
