Custom/Hybrid My refreshed superfreak
IMAG0314.jpgIMAG0315.jpgIMAG0316.jpgThis is my -4.3 carbon Superfreak Badass. I got it used last summer and put it together looking pretty raggedy! I busted my arse to get it all fixed up for Daytona, It was well worth it! Anyway here is the list.
Ported 62t cases, ported 61x cylinder stock bore.
B pipe mod chamber, bored mani and headpipe.
stock 61x electrics.
ATP waterbox.
ADA girdled head.
boyesen velocity intake, stock 44's
xmetal trim, stock pump, 13/17 concord.
RRP AST steering, 50 mm riser bars.
front foothold from Tem, that I added.
I can't tell you how much I LOVE this ski, It was fun last year even with the tray all cluttered up! Now with the tray and holds the way I want them it is like a dream!View attachment 208560View attachment 208561View attachment 208562View attachment 208560View attachment 208561View attachment 208562
I didn't have a strap, I found my toes jambed against the front of the tray before, In surf stance. I really like the front hold! I almost don't notice that my foot is in it, my stance just feels rite now. I taperd my 25mm pad down to nothing just in front of it on the bottom, then two layers 8 mm on the top. I got lucky cause its perfect, I had to do some tuning on normal holds when I got back home, couldn"t kick in good due to the flap going around the rear too much. I would highly reccomend the front hold if you ride surf! I saw your setup there pretty impressive! I need to get my wife riding more!
Crab
thanks darin...noswad!
Seattle
Front strap bolted thru the side, and as far back as you can get it above the midshaft also works really good if you need surf stance.
KTM434
Jamie FN Hickey
Palm Coast FL
I have Tems front foothold also and it makes my riding stance balanced perfectly and helps for getting your weight forward when needed. Your ski looks good, very clean
Thanks for the nice comment everyone! Yes the front hold is the shizz, I am only about 5'8" also, seems that it would be a neccesity for a taller rider, in surf.
