WaveDemon
Not Dead - Notable Member
- Hell, Florida
Now... how do I fix it? Is the problem in the connection, the wiring, or the switch?
yes. :wiggle:
if it's the connector you'll see that it doesn't look good and if you wiggle it the connections should work better.
if its the switch and wires you can check it with an ohm meter on the black and white wires at the connector. it should have very little resistance when the button is pressed.
if you have bad resistance or no connection at the connector open up the switch and clean the inside of the buttons.
the wire is rarely the problem
