Custom/Hybrid My Wifes Rok-r build ....
I have a few to burn up. Ever since they warrantied our last batch we haven't had any issues. I run anti gravities in my personal ski. I will run the ballistic as long as they keep replacing them for free. I don't plan on buying new ones. If I do they will be anti gravities
got the pole back on with the Blowsion pole spring. ( I hope it gets worn in cause there is some serious spring)
Lauren said she was making the cushiest footholds. I jammed my feet in them. There is over 2" of foam. They feel awesome. Hopefully she finishes that tonight and I can get this waterbox re-welded up
It has a different cooling set up. It's set with a single 1/2" quick coupler from pump to hull. I have to try and find a connection for it.
Did some grinding,buffing and filing on the nozzle and trim to get some more throw from the xmetal setup
They are SMC push fittings.
You need a special line with a 1/2 inch outer diameter, I have some of the line here.
You will want to use the SMC push fitting line from the pump(You need 2 more fittings for your pump), from pump, through hull, then after in engine bay, use a 3/8 straight barb fitting to turn it into regular water line and route your regular water line around. this SMC line i guess it rubs through insanely fast if its on a vibrating engine....
Shoot me a PM if you need some line... I couldn't find it for less then 50 feet at a time.. so i have quite a bit left over.
River Rat
Squarenosed
USA
http://www.homedepot.com/p/Watts-1-...PIG25/100186093?keyword=42141525#.UbPF1cu9KK0
^^ There ya go! Wasn't sure if they had home depot in canada, and damn i wish i went there, Went to Graingers cause everyone at home depot just looked at me odd and no one could find it.
x-h20
The stuffs sh!tty it's rock hard and hard to work with ..here's what we did to ours ..3/8-3/8 brass fitting connected to the poly hose and used the lease amount of the poly as possible and connected the regular 3/8 fuel hose to it ..was told when it rubbed it would wear quick ..used it on the pump the most .. Hope this helps..
I have no idea why WDK decided to use push fittings. My least favorite part of my ROK-R. Now I have huge holes in the hull, when he could have just used a normal hull through fitting.
I'm hoping to god i can find one tomorrow. P.s. the ski is looking sick. Lauren is almost finished the turf
