N3vrSat1sfied's Wife's EME Q8 Sky Build
N3vrSat1sfied
Military Member
Fort Worth, TX
Well I have started building a 2nd Q8, this one for the wife, So thought I'd share the progress. Practically stole this hull, it is a 2013 Q8 sky that has never seen water as you can see the breather holes are not drilled etc. It was only 3 invoices apart from mine and ordered 4 days before I ordered mine.
Specs:
HULL:
- 2013 EME Q8 Sky
- Jaz 2 gallon fuel cell
- Xmetal scupper
- Xmetal KDX footholds
- Ride plate cut flush
Engine:
- 701 61x
- Blue anodized Jetmaniac/ADA girldle head
- SpeedySproket Lightened 61x Flywheel
- MagnaPower EXT9
- Bpipe Mod chamber
- Custom Xmetal waterbox
- Single 46mm carb (jetting specs)
- Ada blue throttle wheel
- Prok F/A with pre filter
- JSS Ebox with MSD enhancer
Pump:
- Skat Trak 145 14 vein setback
- Skat trak trim 86/89 nozzles
- EME cone
- 11/17 impeller
- 650sx Driveshaft
- ADA billet Couplers
- Skat SXR scoop intake grate
Steering & Pole:
- RRP Cast pole
- EME bracket with dual breather hose
- RRP bearing steering
- RRP straight bars
- Blowsion Billet throttle lever
- Odessey trim lever
- Skat trim cable
- ODI TLD grips
- Jetmaniac BB Yamaha Throttle cable
- SXR steering cable
Pics when picked up:
IMG_9927.JPG IMG_9928.JPG IMG_9929.JPG IMG_9935.JPG IMG_9936.JPG IMG_9937.JPG
N3vrSat1sfied
Military Member
Fort Worth, TX
First task is getting a Waterbox in. Picked up this Gen 1 Xmetal box for $60 :) Cut the t off but it is still too wide to get up far enough into the nose of the ski. photo 2 (2).JPG Photo12 (2).JPG Photo12 (3).JPG
Got it in the truck right now, Dropping it off with @SuperN8 to have the exit moved from the end of the box to the top (like tdr style)
For Reference here is the waterbox in my Q8: Waterbox1.JPG
N3vrSat1sfied
Military Member
Fort Worth, TX
Some new parts from Factory pipe, Thrust, and @JetManiac.
Everything is here besides a few misc parts, and RRP pole I am picking up from @Roo this weekend, @JamesG has a Skat intake grate for me, and waiting on the X2 nozzles from @SpaceCowboy
N3vrSat1sfied
Military Member
Fort Worth, TX
Got the fuel tank secure today afterwork, didn't take pics yet though.
It's so much easier building one when you have a reference (my q8).
N3vrSat1sfied
Military Member
Fort Worth, TX
Need to clean up the brackets and glue down the front tank wedge. What's everyone use for that? Plastic weld/2part epoxy?
So the rotation of the lid isnt center on this tank, so I had to offset my strap brackets as opposed to being center like mine. Otherwise the strapping is all the same, it is not going anywhere.
uk
Silly question but.... are they handholds on hood or breather holes? You got a pic of where it breaths from hood? Thanks
