Is the 08+ SJ ride plate the same as the old Squarenose plates, with six bolt holes?
Are the holes in the same locations as the Squarenose plates?
Thanks.
Thanks.
That's what I am after.
When I shortened my RN hull, I put the back two inserts into the same location as the middle inserts in a SN hull. This means I must use SN plates.
I guess I can also use 08+ Plates.
The stock superjet rideplates are the same size and same basic casting for all years of superjets.
SN stock rideplates have 6 smaller holes which can be drilled out and used on RN and '08-up sjs.
RN '96-'07 stock rideplates have 4 larger holes but the spots are there to drill for the middle holes. Can be used on '08-up by drilling the middle holes out. Can be used on a SN as is with 4 bolts or drill middle holes and use all 6.
RN '08-up stock rideplates have 4 larger holes but the spots are there to drill out the rear holes. Can be used on SN or pre-'08 RN after drilling out rear holes.
