Need a little help
Ok still no luck is it possible for the stator to be bad?
Just to recap still wont take anymore than 1/4 throttle. Also smokes really bad acts like its on a rev limiter.
I cut the water temp sensor wire and made sure to not have the wires touching each other. I have also tried going back to the stock jetting with no luck.
I called FP they said the is correct 140m and 70p stock needle and seat stck spring with the aftermarket air filters.
The motor (62T) is out of a couch the guy I bought it from claimed it ran perfect (701). Due to the exhaust from the couch not being able to work I bought a type 4 Dry FP pipe.
Someone please help i have had this ski for over 2 months and still have not ridden it yet
Ok rejetted the carbs 70p 137.5m re adjusted the hi 2 turns out and low speed screws 1/2 turn out replaced the pop off springs with 90g springs ran great for about an hour then fouled the plugs what gives please help me I really want to get this thing running good.
For those who care I think I am getting closer...... I turned the low speed screws all the way in and turned the high speed screw in to about a 1/2 a turn and it runs good still a little rich on the bottom end but I am going to rejet the pilots to get that out but I finally got to run a whole tank full of fuel through the ski.....:bananajump:
