Need Help!! Water In Octane Cdi Box
I had some starting issue with my ski it finally would not start. I moved the cdi box around and it started right up. There is a lot of water in the cdi box. What should I do to clean it. I got the water out and I sprayed it with wd-40. Will the cdi still be good? Like I said It has weak spark, but does start once I shake box around.
E-Box
Send me the complete box, and I will fix it.. Toss the fire exingusher from it's OEM location, as it bends the e-box lit and allows water intrusion.
Thanks,
Randy
