Need help
Trying to fix a wave raider for a friend. The compression is 130 back and 150 front. It has 46 mm
Buckshots 110 main not sure of pilot jet. Pop off around 12psi. Stock exhaust,riva f/a. Please watch video.
Bigger jets if so what size?
Any ideas would help thanks.
Can't see a video link. As per previous post, variation in compression between cylinders is more than 10% and needs to be addressed first.
Is the engine a 701 or a 760? 760's have staggered compression and run a little less on the rear cylinder in stock trim. Variation is still excessive, even for a 760.
for some reason I cant download video. Ill see what I can do. was trying to post for a buddy of mine bc he had the same problem uploading. Might be the format of the video. appreciate the comments so far.
