Need my driveshaft lengthened..
Tuscaloosa, AL
Better to shorten than lengthen. Adding on to it plus keeping it true and strong enough would be a chore. You would either have to cut it and add a section in the middle (2 welds) or add to the length at either the threads or spline side. Remachine and true.
SUPERJET-113
GASKETS FOR CHAMP BRAP!
I have plenty(4) of Yamaha 144mm pump long drive shafts from sitdowns in great condition. They are still in the pumps but i can separate.
PM if interested. I'll make you a good deal and could send it to Watcon or SnowXer guy who does this also.
yamanube
This Is The Way
Staff member
Mandalor
He needs a kawasaki driveshaft.
Foximus
CFL Cheapass.
Oviedo, Fl
550sx is the longest kawi shaft made as far as I know.
Lots of room to work with chopping down. Both in front of and behind the bearing block.
