speedysprocket
Alex
- Chesapeake, VA
I'm in CT right now if you need help. Live in North Haven, boat is in Chester on the river...
you might be over propped
do you know what pitch you are running
ok people i dont know what to do about my issue heres what i have done and my other options what do you think?
DONE/Checked:
Carbs: 140 mains 68 pilots 20 psi pop off and carbs are clean
!60 psi compression in both CYLS (new top end and high comp dohms)
New coil
cut the ends of the spark plug wires
check the tuning ports in the exhaust (clear)
checked the reeds, LIKE NEW
NEW GAS
ohmed the stator everything according to spec
OTHER POSSIBILITIES:
- bad crank seals
-crank out of phaze
- fly wheel key scheared
-wrong impeller (too big of a pitch)
-Bad CDI
-Bad stator
IDK what to do any more sick of working on this thing and dragging it to the boat launch to have the same problem everytime
runs the same with or without the hood and the flame arrestors, there is no exhaust leaks, the engine is original except for new top end and high comp dohms
so i pulled the pump apart it has a 15/23 impeller in it
