I went and put on wrestling shoes and put old pieces of turf on the bottom of the hold, did some measurements, and a little over an inch of the old turf makes the hold snug.
Turf itself is about 5mm thick, so then I'd only have around 15mm of underpad to use in the holds. I need some pad on the inside top of the holds too, so I don't think 25mm pad is ideal anymore.
Is really thick pad crucial in the tray?
If I use 25mm pad, it won't do any good for the footholds, cause I'll have to sand it down so much.
Unless thick pad is super important in the tray(besides inside the footholds), I'm thinking about doing 9mm plush in the holds and the whole tray.
