- Maine
Just finished rebuilding an sx650 pump for my newly built flatdeck... Well I tried it out today and it seams to have found neutral? It will ideal a bit than all of a sudden it's like someone puts it in gear! Than it will go and plane and pop back into "neutral"?? What gives.???!! Impeller not in bad shape, but I did not put in two steel fender washers that separated impeller from bearing seals in pump. I thought these were rigged parts so didn't include them in rebuild.... Do people shim impellers to the drive shaft splines?
