Shrivel
Requires therapy.
- Acworth, GA
sounds like an air leak somewhere that mostly corrects itself once the joint expands from the heat. all your bolts tight and gaskets in good shape?
Just got back from the water and problem has been fixed. It's just a bit rich now, so I'm going back to the 70 pilot or possibly a 72.5 whichever feels better. Thanks for all the help.
One last thing, what should I use for a restrictor to the stinger? 2.5 needle seat? Nylon spacer with hole drilled? Or should I just get the FCV from JetWorks?
I used a FCV and a 2 or 3mm restrictor at the stinger and it never got too hot and really worked great.Nevermind, just ordered an FCV from Legdrag.
Did it improve your "just off idle" pull quite a bit? Mine takes a second to "clear out" before it really starts to pull. I don't think it's a carb issue.
