- Alexandria, VA
Here is my two cents on learning to turn when new to riding...at least what worked for me.
Dont be afraid of the throttle.
Perfect the leaning to turn by throwing your foot on the desired side of intended direction. Once you get that down it will help you feel more stable.
Pretty much once you get down the concept of turning the bars in the opposite direction of the way your tipping over, you will also feel a lot more stable on the water.
If you can turn left (or right) better then the opposite, perfect that direction and you will use what you learned on the more comfortable side to help you improve the other. I kinda relate that to when I learned to snowboard.
Definitely dont be afraid of it.....Im sure you have already notice, the better you get the more fun you have.
I recommend just practice practice practice your turning and before you know it, it will come naturally.
As you get more comfortable with the ski, you will learn a bit more about placing your wait forward and aft to keep the pump hooked up and not have the ski bounce all over the place.
It all just takes time.... Thats just my two cents...Im not too many years off from going through these trial and tribulations myself so.....the above is the advice I think I would have liked to hear. Hope it helps.
