So I go out to look under the hood of my ski. Background, its uncovered and I havent checked on it for about 2 months. When I open it up, its got water up to about half-way up the carburetor. I nearly shat myself. Batteries dead, battery cable are corroded and the motor I think has rust in it.
I really dont want this to be true, so Im asking you guys. I turned it over by hand and it went smooth for one stroke then on the second stroke I met resistance and heard grinding sounds. This is completely not normal and there is rust inside right?
Also whats the best way to go about and fix it as cheaply as possible? Should I get the crank rebuilt via SBT and can I reuse the pistons? Should I buy another motor and part this one out? Any other ideas? If someone wants to trade, Ill throw in cash and this motor for a working one with 200 or less hours on it.
