- COMMERCE TWP, MI
I just started my new build for the first time yesterday. It started up but sounded off. I ran if for a little bit on the hose and found one cylinder warm and the other ice cold. Poped the plugs and one cylinder is not detonating. Cylinder is getting fuel as it is ending up in the pipe chamber. I checked compression and I have 180 in each hole. I also. He k spark on both plugs and no trouble there ( bright and blue). I thought it might be a timing issue so I pulled the front cover and checked the key and stator timing mark and both are in the correct positions. I'm kinda at a loss of where to look next? Any help would be great
Background on the ski: 771 big bore ( nicely ported) built by #zero. Vf2 reeds, Ada head with 35cc domes, factory pipe with mod chamber, fresh built sbn 44's with a reed spacer, a/m flame arresters, 61x electronics, msd enhancer and msd coil.
