New Nose For the Square Nose
Midlake Crisis
Bakersfield, CA
You've probably already reinforced it and don't want to make any cuts, but a small slope in the front that complements the hood lines going into the nose could look real good. My drywall method works real good for tiny patches like that. That's what I was going to do with mine but switched hulls. The stock X2 uses a small hole with a hose that runs over to the pissers to let water drain out of the fuel fill area.
The drain hose would be super easy like my SXi Pro has. The nosepiece is still removable so no issues getting to it. Another thought was to cut a "V" channel from the bottom of the fuel fill circle to the center of the nose (where the bow eye usually is) to let it drain fast externally.
