Big Kahuna
Administrator
- Tuscaloosa, AL
You could build you a new ski and use it!!!!!!!!!!!!! LOLIn stock ready to ship
I've seen them on 701s before and they work well run wet. That will get the bottom end back that helps the smaller engines. Will have to drill and tap a hole for a spray bar in the exhaust manifold just before the chamber coupler and tap the spray bar for a mikuni main jet so you can adjust how much water injects into the chamber. The rrp lay down pipes are set up this way.its my understanding that the laydown pipes are for big CC only. would this work like a b pipe on a ported 701? or is it too much?
These are too, I bought mine from tricky last fall and it came tapped for water injectionI've seen them on 701s before and they work well run wet. That will get the bottom end back that helps the smaller engines. Will have to drill and tap a hole for a spray bar in the exhaust manifold just before the chamber coupler and tap the spray bar for a mikuni main jet so you can adjust how much water injects into the chamber. The rrp lay down pipes are set up this way.
