Haha,
Right up until you have to take the cylinder off the kawi.
After some grinding, this is my b-pipe (and type 4 manifold) wrench:
No you dont.... it is imposible to get them to turn a full turn with a regular wrench.
You can get them to do as many turns as you like providing you removed all the other bolts. Or, you just loosen them enough for the manifold to slide out from under the bolt head.
Well i must have had a super thick wrench then cause i couldnt turn it far enough to get to the next point to put the wrench back on.
I have those wrenches in my box and they are not the ticket that u think they are. I have tried using them and they really don't help any.
Do the grinding on a normal wrench and u WILL be happy.
I use a normal open ended box wrench that I ground real thin and also ground down the outer edges as well.
