So this is my first year doing mods on my 2014 SJ and I have done a few minor ones so far like ride plate, intake grate, impeller, bars, bilge pump, etc. So I am learning here bear with me. This is my first "motor" work.
So anyways, I pulled the carb today and drilled out the anti tamper caps. I have already ordered the T screws from Jet maniac so I was prepping it for this. My plan was to keep the stock settings for now but I think I drilled a bit too deep and turned the screws. The only mods I have that would affect the need to adjust the carbs are a/m f/a's and a primer kit.
2 questions:
1)is the attached picture showing the actual stock settings for my SJ that I need to follow and get back to?
2)Should I follow these and just turn the high speed adjusters out like a 1/4 turn to richen it up a touch? I was told that the F/a's and primer will cause a need for a bit more fuel.
Thanks in advance!
2 questions:
Thanks in advance!
