- Huntingtown Maryland
so for a newbie that just owns a JS550 ski and wants to do flatwater back flips, wake back flips and to just ride seems like the best bet is to get a whole new ski. That being said without dropping 4-8k on used ski I think I would like to start off with an engine and build it myself over the winter. So if I was going to start with an engine which one should I start off with 61x, 62T or 64U also having in mind to beef it up if need be on the cheaper side? I'm thinking 62T?
So starting off crankcase which would be the best choice used/new if used what should I look out for? New/used can you buy one with striker mod is this even needed or get it modded further down the line and buy a used running engine at moment?
Crankshaft new/used? Size?
Cylinders? Buy one new/used? Should it be new/used with cylinders bored out? Bored out to what extent?
Head? Buy new/used
Exhaust- new/used?
Intake new/used I'm going with ported definitely.
Carb new/used? Size? Single/double?
Exhaust-new/used?
Flywheel new/used? Lighten?
Electronics new/used? Total loss electronics new/used?
What else am I missing that would be very important besides Hull/Steering/gas tank?
Head? Buy new/used
Exhaust- new/used?
Exhaust-new/used?
