no bottom end power!
bored&stroked
Urban redneck
AZ
So previous owner got it in trade and knows nothing, and you know nothing. Its a factory single carb intake. You sure its not a 650 engine in there?
Michigan
I'd pull the head and see what bore the cylinders are at. If the top end is 650 as well, then no point in bottom end swap. Can't remember what 650 bore is but 701 bore would be 81mm and if it's truly a 760 the it should be something like 84mm
maxboost
Super tuned
Ia
Okay I’ll try that tonight, thanks for all the advice guys
when you get the head off measure from the deck surface to when the exhaust port opens with a micrometer, with that you can figure out exh duration and that will give you an idea of when your power is going to come on
maxboost
Super tuned
Ia
Ontario
Update, head was pulled and cylinders are bored to 84mm and Can anyone tell if there was any porting?
Is the motor a turd and has no power or is the pump slipping like your original post indicated? If it’s slipping the wheel then adding more power is only going to make the problem worse.
Definitely ported. The problem is in your pump if you are describing slipping. Pull pump to check impeller condition/clearance. What cone is in and what size is the exit nozzle?
schicks
Karma Enforcer
West Michigan
Might be way off, but i just got done chasing my tail on an issue where my ski wouldnt rev out correctly, seemed to bog almost. The low end torque was terrible, but i could pin it across the lake and it would go. ended up being a bad stator. My check order was swap cdi, coil, went through carbs, then swapped stator and that ended up fixing it. Stator looked brand new, but somthing wasnt right with it.
Ontario
Update I took the pump unit out, it has a solas 13/17 prop in mint condition, it is a 144 pump unlike the guy said, (I’m assuming stock superjet pump) the exit nozzle is 94mm
You mean 84mm on the reduction nozzle?
Clearance is good
What cone?
You can cut the impeller for setback (and/or take washer out), will help hookup
Leading edges of pump vanes look damaged, need a better pic
Ontario
Sorry yes i meant 84mm and it had a stock superjet cone, and the vanes have some pitting on them but there is no major chunks or anything taken out of them
Is the 13/17 with the 144 pump a good setup for what I’m looking for?
Quinc
Buy a Superjet
California
Buddy just had this same issue with a wsm stator.
Really think the pro would me a good start. Jetmaniac or impros could get you the prop for your setup. Being a 760 with bolt ons I would think you would be better with a 10/16
Ontario
The spline looks good, and okay thanks for all the advice guys, I’m gonna look into it a bit more, maybe get a 62t bottom so I can have the bigger reed cages an duel carb and maybe invest in a lightened flywheel and impeller
