No spark with plugs IN the cyclinders
Troubleshooting my 750 small pin. No spark/no start. When I let off the starter I get a couple flickers of spark. This is using a second set of plugs (one set in cylinder, on set in the plug caps grounded to head.) If I remove the plugs from the cylinders (plug holes open) and crank, I get good spark. I tried two different batteries, both are from 06/23, both have been kept on tenders. I am waiting for one the trickle charge back up to test again.
Thanks for the help.
That's what I'm thinking too. Just confused as to why it'd spark with no compression and not spark with compression, what causes that?
A stator is a coil of wire with a magnet spinning around it , the faster it spins the more voltage it produces , it spins much faster with the plugs out than it does with them installed.
Gotcha makes sense. Should it still be producing spark with a weak battery? I usually replace my battery every season. This year I didn't use this ski so it's a battery from 2023. I am wondering if there are dead cells in the battery.
Yep anything below 10.5 volts while cranking is not good , a damaged starter or weak battery can both be culprits here , I have seen some starters out there that drew tremendous amounts of amperage.
If I was working on this ski the first thing I would do is put a known good battery in it , just for elimination purposes if nothing else , my philosophy on electrical diagnostic is start with the simple stuff first eliminate that , new battery , unplug the stop switch and go from there .
I recommend do what wfo is saying here.
I have had weak magnets in the flywheel cause the same thing…
3 of them were Jetinetics charging wheels on a 550
jetinetics flywheels are notorious for this , I also have a really nice Jetinetics paperweight - doorstop for a 550 here somewhere .
