I do a lot of subbing. I have a scupper.
I havee currently oem inatke (chokes removed, 2 filter screen removed + R&D angled reed spacer), I bored the nozzle to 84mm, my prop is oem 2008, cutback by 2,5mm + wetwolf cone.
My cylinder is being bored right now to a 727 with porting for bottom end. I will have a hi comp head @ about 180 psi. I have a modded b-pipe too (bored, polished, etc)
I generally know how to adjust my carbs, I know the procedure. What I don't know is whether boring the carbs (v-type intake) and boring all obstructions and adding the atomizers will be good or not. Need input mostly here...
I understand that I will need to make jetting changes after porting is done, or can I stay with the jetting recommended 701 for B-pipe application? This is also of big importance to me. If you can advise - I will be obliged.
