hi.
i have a 2008 sj with single cooling line and b pipe. i have 2 pissers. the first comes directly from the head and the other from the front and the back of the pipe to a tee and than out.
the cooling route comes from the pump to the exhaust manifold and from the head to the pipe.
when i run the ski in the water nothing comes out from the pissers.
if i connect the flush kit water comes out freely from the head if i disconnect the hose from the pipe but if i connect the hose from the head to the pipe i think the pressure from the pissers is lower than normal.
where should i check for the blockage?
