Novi 48mm Carb Dimension
Can anyone tell me what the OD of Novi 48mm carb inlets are? My Full Spec 49s are 2.80" OD with a 118mm center to center spacing. I'm assuming all 62T carbs are going to use the same spacing? Any other large aftermarket carb inlet ODs would be helpful too...
Thanks!
usa
most later model intake manifolds are 118mm spacing
some of the early manifolds from r&d and rivas were 102mm spacing
if your talking about the air horn where the filter clamps on are usually the same on aftermarket carbs
