OEM 144 pump
SkiPro
Trim down for what!?!?!?
E-Town, Ok
I have been outta the sport for the last 3-4 years and I’m unsure of prices on parts. I have a complete oem 144 pump with a superjet length drive shaft splines are perfect spins smooth no play. It’s tapped for dual cooling and has OEM wear ring that’s mint. Inside is a mint 9/15 hooker prop not a ding on it. The reduction nozzle is one of those +5 degree up tilt nozzles that’s been bored and has had all the ribs bored smooth. Unsure of the bore size. Also have a 62t oem trim ring and a steering nozzle. That could go with it. Ready to be dropped in someones hull. What is this worth? Is it worth it to sell everything seperate or sell it complete and what would it be worth if so. Thanks in advance! Also if anyone sees this that needs a RTR pump make an offer I guess? I dunno what to ask for it
MarkWalker
Buffalo NY
Bet, thanks! Anyone have any ideas on what the pieces would normally cost in good shape?
Pre 08 OEM shaft- $125
Clean 9/15 Hooker-$200
5 degree Reduction nozzle-$75
steer nozzle-$30
OEM wear ring-$50
OEM Stator- will sit on your shelf until you throw it away.
*All prices are + or - a bit!
