Oem 155 Stator , SBT wear ring, WSM shaft, Thrust trim. All parts were purchased new, 25gals through set up. Includes Imp spacer, oem pump seal, dowel bushing/spacers, threaded SBT wear ring that allows you to use readily available bolts for pump housings. The housings have been clearanced for steering cable throw, top of pump box. 90.8 Nozzle bore, 93 Steering Nozzle bore. Everything in pics $1100 + pp +ship.
